Home > Maintenance & Modifications > washer jet upgrade... any thoughts...
Page 1 of 4 1234>
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Has anyone fitted this type of wash wipe upgrade at all?
Any issues?
http://www.ebay.co.uk/itm/201763337327?_tr...EBIDX%3AIT
John 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #595417 22nd Jan 2017 8:06pm
grafty99
I think the only issue is see is neatly running the pipes and much more exposed pipes and so more prone to freezing. Definitely good for washing the screen though. My dad's iveco van has them and they are brilliant Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #595422 22nd Jan 2017 8:11pm
Romadog
I have a similar system on mine and works well.
Having experienced driving 1000s of miles towing a trailer with a Defender and therefore in the firing line of lorries spraying salty water on the motorways at this time of year, I made sure that I did this conversion so the wipers had a lubricant on the first wipe and not on the 3rd or 4th once thw wind has stopped diverting it ! Thumbs Up
Post #595453 22nd Jan 2017 9:06pm
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
I'd prefer to go with there other kit as I have aero blades. https://www.ebay.co.uk/itm/201661218144
Post #595481 22nd Jan 2017 10:11pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
when I get chance I'm going to do either this or put two extra std jets using the pump and switch from the rear wiper to activate them.
This way I have the normal jets for everyday driving and the ability to flood the screen in real bad weather or offroading before the wipers even move 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #595489 22nd Jan 2017 10:27pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
I've done this and can't praise it enough, one of the best driving aids, especially at this time of year when the roads are wet and grimy. Also seems to use less washer fluid.o
Post #595501 22nd Jan 2017 10:58pm
VVS210
BuckBlu110 do you have any photos of the mod in situ please? - how have you dealt with the existing central washer jet & how have you routed the pipes to each wiper arm from a central exit on the bulkhead? Cheers.
Post #595518 23rd Jan 2017 7:54am
One of the easiest and neatest upgrades is to replace the single washer jet with two:
More details here:
http://www.defender2.net/forum/post232942.html#232942 Darren
Post #595525 23rd Jan 2017 8:50am
BuckBlu110
VVS210, I'll take some photos of both my csw and double cab, it'll help explain. I've done them slightly different but the effect is the same.
Post #595527 23rd Jan 2017 8:55am
One of the issues with the standard set up, or indeed the two jet modification as shown above, which bugs me is that the nozzle is so close to the plane of the screen that the jet of fluid hits the wiper, and it is difficult to get fliud to the upper side of the wiper blade. A loooooooong squirt is needed to clear the screen throroughly, using a lot of fluid from the woefully inadequate reservoir. I cannot see that fitting second nozzle assembly does anything to improve this.
It is my intention to upgrade to the arm-mounted quad-nozzle arrangement when I get time.
Post #595529 23rd Jan 2017 9:24am
VVS210
Thanks for the photos of the twin jet set up, looks nicely symmetrical. Look forward to seeing photos of the two set ups BB110 has. Cheers.
Post #595533 23rd Jan 2017 10:01am
geobloke
The nozzles on the defender are really quite pathetic, certainly an upgrade from the series version but not by much.
Many many years ago now I put together this system based around the Peugeot wiper blade mounted washer jets. Loved this mod as the water was directed to exactly the right place on the screen.
http://www.reedx.net/landrover/mods/wipers/
I expect the washers are hard to come by these days. Plus the piping was as tidy as I could get it to be.
Like the idea of the wiper arm mounted system, but still the issue with the supply pipe being routed through the front of the bulkhead.
Which is why nowadays I have gone for the twin Defender nozzles and they work well, but as stated it can be a pain to get the water to the top of the screen. Added to this the OEM nozzle I bought for the second half of the screen seems to have a mind of its own when it comes to water jet directionality and sometimes produces the perfect jet and more often thean not creates an ineffectual fan that doesn't reach the screen.
I have often played around with the idea of modifying a set of Disco 3/4 heated washer nozzles. I have seen them mounted on the the defender bonnet somewhere, but that seems like a stretch in distance and upward angle to get them to work well with a defender. Actually bought a set to play around with. Perhaps I should revisit the idea...
Post #595535 23rd Jan 2017 10:06am
blackwolf wrote:
One of the issues with the standard set up, or indeed the two jet modification as shown above, which bugs me is that the nozzle is so close to the plane of the screen that the jet of fluid hits the wiper, and it is difficult to get fluid to the upper side of the wiper blade. A loooooooong squirt is needed to clear the screen thoroughly, using a lot of fluid from the woefully inadequate reservoir. I cannot see that fitting second nozzle assembly does anything to improve this.
In practice, that wasn't the case. The twin streams from each jet found their way around the wipers and because the water was delivered more closely to where it was needed, less was required.
I've just bought the bits to carry out the same mod to my current 90, if it ever warms up enough Rolling Eyes Darren
Post #595536 23rd Jan 2017 10:09am
JOHNT01670
many thanks for the responses, information and links which have proven to be very useful indeed folks....
waiting to see BuckBlu110's pictures...
Thanks again
John 2006 TD5
Post #595733 23rd Jan 2017 9:08pm
Romadog
Sorry best pic I have of my setup
Post #595750 23rd Jan 2017 9:34pm
Page 1 of 4 1234>
