![]() | Home > Maintenance & Modifications > washer jet upgrade... any thoughts... |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 ![]() ![]() ![]() |
The jets looked to be part of the wiper body so unless the rubbers could be swapped I assume a new unit would be required.... 2006 TD5
2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
Exactly what I thought. Seems an expensive way to buy new wiper blades! TD5 Defender 90
Discovery 3 HSE |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
On my set up, the jets are clipped on to the wiper arm, so any blades can be used.
5 POT Member Since: 24 Nov 2014 Location: UK Posts: 81 ![]() ![]() ![]() |
On a similar idea has anyone tried heatshot?
http://www.heatshot.com/uk/ Fancy doing this on the Defender to get rid of flies in the summer with near vertical windscreen! |
Just fitted these to mine http://www.ebay.co.uk/itm/201661218144?_tr...EBIDX%3AIT
Only took about an 40 minutes from start to finish with a bit of ![]() ![]() If I ever take out the dash, i'll fit the nice double jet setup as it looks more OEM. TD5 Defender 90 Discovery 3 HSE |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
has anyone tried fitting bonnet mounting spray nozzles? My wife's 1 series BMW has great spreader nozzles that coat the windscreen better than a single jet. Wondered if this might be a good mod to do. They also have a heater element built in which I assume could be wired up with the windscreen or mirrors if you have them. Would have to work out best place to fit and angle of spray including when driving at some speed. Personally don't like the look of those pipes coming out of the bulkhead and they would surely freeze in the winter.
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10894 ![]() ![]() |
^ ^ ^ I dont know what jet nozzles he uses but grafty99 has fitted some to his bonnet, you can ask him
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Funny you should mention this, I pulled out a set of Disco3 heated washers from the spares rack last weekend... Thought to me self... Huh... That'd be cool on the 110. These are the jet versions rather than the spread type of the later disco3s. Look to have a good range of angle they can work through. Figure you might be able to fit them to the slope at the back of the bonnet to direct them a tad... Not sure...
Thats what I thought also. The sloped angle might tuck them neatly away and still allow the spray to hit the window fine. I just ordered a set of used heated BMW jets with pipes and wires attached for £20 to see if this might be feasible. What do the disco jets look like?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
I do indeed have two washer jets on my bonnet. I'll get a picture when it's light.
I have 2 twin nozzle jets and any speed over around 40 mph they SOAK the whole screen just like the VW/BMW ones do when stationary. When below 40 mph they spray nicely in the wiped area ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Here is my setup
![]() ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Assume the result is better than a single or double washer setup on the bulkhead?
It is. I have tried both. This is definately the best for actually getting the screen wet
Like this; ![]() Twin Jets rather than fan spray. |
