Home > Td5 > Leather steering wheel
Will osborne
United Kingdom 2005 Defender 90 Td5 HT Java Black
Hi I've got a 2005 td5 and would like to upgrade the standard steering wheel to a leather xs one. Am i right in saying i can get one off a puma up to 2014?
Regard Will
Post #593707 17th Jan 2017 12:17am
mk1collector
Your best taking your wheel off and counting the splines in the middle. My td5 is 36 spline and most if not all pumas are 48 spline but apparently Landrover could have put either size in randomly from what I've read. Ray
My build thread
Post #593715 17th Jan 2017 12:34am
Will osborne
Im pretty sure it is 48, so if it is it will fit fine?
Post #593750 17th Jan 2017 7:40am
grafty99
Apart from 2015 onwards model year as they had a steering angle sensor so won't fit. Anything with the same number of splines up to 2015 will be fine though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #593761 17th Jan 2017 8:28am
Martin
Site Admin
I've updated this with details of the DSC wheels:
http://web-rover.co.uk/articles-steeringwheels.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593776 17th Jan 2017 9:53am
Will osborne
Ok thanks
Post #593820 17th Jan 2017 1:55pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Have a 2016 puma steering wheel on my 02 td5.
You need a little mod to that to tack on the turn cancel "knuckles" and it will work great.
Alternative you can manually flick the indicator back. The defender has migrated, leaving the owner behind.
Post #596749 27th Jan 2017 3:11pm
Will osborne
Do you just make up some tabs the same as on the original wheel and weld them on the MY2015+ steering wheel?
Post #596969 28th Jan 2017 2:40pm
achuakh
Or you do see like a track where you can fit in a small bolt, both top and bottom, that will also allow for that to push the blue ring on the turn cancel.
Squeeze one in and tack weld it and you are good to go. The defender has migrated, leaving the owner behind.
Post #597975 31st Jan 2017 10:16am
X4SKP
Looks like your well on the way Will osborne to sorting this out...
but for others wanting to know where they are starting from...
Good Luck SKIP
Post #597978 31st Jan 2017 10:25am
Thon
Yes it can be either - my '07MY Puma is 36 spline. Definitely worth checking.
Post #598092 31st Jan 2017 6:42pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I`ve got one..lovely Very Happy
Post #598095 31st Jan 2017 6:52pm
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
I've got one on my 05 Td5 90, it was a 2012 48 spline, good year to get as you can still use your indicators
Post #598142 31st Jan 2017 9:05pm
Martin
Site Admin
X4SKP wrote:
I've updated it since your screen shot Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #598149 31st Jan 2017 9:25pm
