Home > My Defender > Early 110 2.25 diesel |
Franks 110 finished with an Isuzu lump in it. He's moved on to Range Rovers now, though. Darren
15th Jan 2017 7:47pm |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
What a great response,,, never knew there was so many left, mines was written off, the rear axle was bent, it took the brunt of the collision, the roof came of as I rolled thru a hedge, it had a new [ black ]chassis on it. sold it on,
I"v a 300tdi M reg , [ eary too, with 333,000 miles on her, never broken down ,, the clutch rod pushed thru, [ 140.000] , but I still drove it home . [ started in low 2nd] and worked up the gears, original starter replaced @ 280.000mls |
15th Jan 2017 8:11pm |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1286 |
Don't often see an early Roan Brown truck cab. gcc130, help me with my memory, did you put a pic of that on the Series Two forum a while ago? Anyone interested in early One Tens or early Ninetys should be on the Facebook page of "The Stage Two Register '76-84". A bit of a dry title, but some interesting stuff on there. |
15th Jan 2017 9:16pm |
White Wheels Member Since: 15 Jan 2017 Location: Cambridge Posts: 5 |
I have a One Ten pickup as yours, a base model 2.3 Petrol B725 PKV I also had a Ninety B822 PKV, My One Ten was built in May 83 but registered November 84 |
15th Jan 2017 9:32pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 753 |
Yes Slideywindows, it was discussed on the Series 2 Club forum a while ago. I don't do Facebook but see the stage two page via my son. Perhaps we could also have a running thread on here for early one ten/ ninety as someone suggested earlier.
White wheels, do you still have your one ten? It would be good to see some pictures. |
15th Jan 2017 10:14pm |
I have a One Ten pickup as yours, a base model 2.3 Petrol B725 PKV I also had a Ninety B822 PKV, My One Ten was built in May 83 but registered November 84[/quote] So, Mr White Wheels, you got my phone message about this thread then! |
15th Jan 2017 10:24pm |
Hi I do still have the One Ten, I have some photo's from when I purchased it in 2010 , I will see if I can add. Click image to enlarge |
16th Jan 2017 8:59am |
Click image to enlarge Here's another photo, The tailgate is a different shade of green, and there is evidence that it had a rear door at some point ? a shadow mark where the lower door hinge was and a hole in the floor for the door restraint. |
16th Jan 2017 9:07am |
Bows Member Since: 07 May 2012 Location: Wales Posts: 513 |
Took the hard top to work today
Click image to enlarge 2006 TD5110 station wagon 1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
26th Jan 2017 6:36pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10830 |
^ ^ ^ nice pic Clayton.
1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
26th Jan 2017 8:06pm |
Bows, what engine do you have in the One Ten?
If its a 2.25 (P or D) how well does it tow that trailer? |
26th Jan 2017 8:07pm |
It was originally a 2.25 diesel, I have now shamefully replaced it with a 200tdi. In original spec it simply wouldn't have been up to the job. I once loaded the back with logs and had to make almost the entire 20 mile drive home in low range. It wasn't much better empty therefore I decided that if I wanted to enjoy using the vehicle i had to take drastic action. The 200 makes the vehicle but I did keep the 2.25. 2006 TD5110 station wagon
27th Jan 2017 10:28pm |
Did you change the transfer box?
Mine is very low geared, runs out of steam at about 60 with the 200 tdi fitted. |
28th Jan 2017 8:44am |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 |
I quiet like early 90s & 110 but sooo many have been lost the US market!!
Do you need to be a geek to own one? Working towards Carry on camping! |
28th Jan 2017 1:00pm |
