Home > Maintenance & Modifications > High beam. Fault. Help needed puma 2014 |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1764 |
Headlights work OK?
Probably be the stalk. As far as I remember, the puma has the same terrible design as defenders dating back to the stone age. |
12th Jan 2017 9:46pm |
Highfellzippy Member Since: 05 Oct 2014 Location: Yorkshire Posts: 42 |
Yes headlights work ok
Flash works good high beam not latching or putting blue light on |
12th Jan 2017 9:49pm |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
Most likely its the internal switch.
Are you running halogens? Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
12th Jan 2017 10:01pm |
No full led
12th Jan 2017 10:02pm |
Have they ever worked?
Latching main beam only comes on when ignition is on and dipped beam is on. |
12th Jan 2017 10:05pm |
LEDs were on when I got it
12th Jan 2017 10:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20469 |
Is your dim dip resistor disconnected? Yay or neigh if they were working before but suddenly stopped it won't be this.
It maybe be though if you've just fitted LED's? It could be the main beam stalk, does it physically latch in place but still not work? If so it maybe the contacts, physical check by viewing contacts and testing would be the way forward. If you wanted to just skip this you can replace the main beam stalk anyway, they are not overly expensive to buy. But may still not be the culprit. I cannot see you needing to actually fit resistors as I've not heard of anyone having those issues. If everything was working and now isn't there is obviously an issue that has occurred but not one that was present previously. As already mentioned you do need dipped beam turned on, on the main light switch before the main beam stalk will latch. If it seems only on sidelights then it won't latch. This enables you to flash headlights even without and lights on. Both switches could do with checking, both can cause issues. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Jan 2017 10:59pm |
Forgot to say, there is also the Relay.
It may not be latching as it should. Unfortunately I don't know the location though off the top of my head, if the stalk physically latches in place and the main beam still doesn't work this is also a possibly culprit. Hopefully someone can supply a location of it and wiring diagram. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Jan 2017 11:04pm |
13th Jan 2017 9:35am |
