Home > Maintenance & Modifications > High beam. Fault. Help needed puma 2014
Highfellzippy
2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hello I have no high beam on the stalk
It works fine on flash
Blue dash light works on flash
But not on stalk
Car has some led lamps I'm just wondering if I need to fit resistors to high beam circuit
But if anyone's had the same fault let me know the solution please
Post #592598 12th Jan 2017 9:41pm
miker
Headlights work OK?
Probably be the stalk. As far as I remember, the puma has the same terrible design as defenders dating back to the stone age.
Post #592603 12th Jan 2017 9:46pm
Highfellzippy
Yes headlights work ok
Flash works good high beam not latching or putting blue light on
Post #592604 12th Jan 2017 9:49pm
Alexke
Belgium
Most likely its the internal switch.
Are you running halogens? Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #592611 12th Jan 2017 10:01pm
Highfellzippy
No full led
Post #592612 12th Jan 2017 10:02pm
miker
Have they ever worked?
Latching main beam only comes on when ignition is on and dipped beam is on.
Post #592614 12th Jan 2017 10:05pm
Highfellzippy
LEDs were on when I got it
Post #592615 12th Jan 2017 10:06pm
Is your dim dip resistor disconnected? Yay or neigh if they were working before but suddenly stopped it won't be this.
It maybe be though if you've just fitted LED's?
It could be the main beam stalk, does it physically latch in place but still not work?
If so it maybe the contacts, physical check by viewing contacts and testing would be the way forward.
If you wanted to just skip this you can replace the main beam stalk anyway, they are not overly expensive to buy.
But may still not be the culprit.
I cannot see you needing to actually fit resistors as I've not heard of anyone having those issues.
If everything was working and now isn't there is obviously an issue that has occurred but not one that was present previously.
As already mentioned you do need dipped beam turned on, on the main light switch before the main beam stalk will latch.
If it seems only on sidelights then it won't latch.
This enables you to flash headlights even without and lights on.
Both switches could do with checking, both can cause issues.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #592641 12th Jan 2017 10:59pm
Forgot to say, there is also the Relay.
It may not be latching as it should.
Unfortunately I don't know the location though off the top of my head, if the stalk physically latches in place and the main beam still doesn't work this is also a possibly culprit.
Hopefully someone can supply a location of it and wiring diagram. $W33T $0U7H3RN $UG4R
Post #592645 12th Jan 2017 11:04pm
Highfellzippy
Post #592710 13th Jan 2017 9:35am
