Home > Maintenance & Modifications > Hot Running water in a 110 ? Whats the options
TJ101
As above really
Looking at the options out there for fitted a hot/cold water supply
Water Tank,
Heating it up
Delivery Pumps
Got a few ideas in my mind so far, just wondering if anyone has done it, and how ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #591977 10th Jan 2017 11:12pm
g-mack
Post #591983 10th Jan 2017 11:24pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
hot water
One of these was fitted in the rear door of my 110 when I first bought it. Probably the easiest solution
http://ncass.org.uk/store-area/products/ha...ndeman-12v
Chris
Post #592089 11th Jan 2017 12:26pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I bought a Webasto system from someone who was going to run a hot water window cleaning service. Standard Webasto with an additional water/water heat exchanger with a thermostatic valve. Never quite got around to fitting either.
Was toying with the idea of teeing the heat exchanger into the coolant lines directly, but then thought that having the V8 running while trying to have a shower/wash might be a bit loud.
Link to heat exchanger: https://www.butlertechnik.com/installation...209a-p1516
Post #592094 11th Jan 2017 12:45pm
JOW240725
A lot of the utility company vans have hand wash facilities such as http://www.tealwash.com/shop/compact-classic-motor-vehicles/
But thinking you might be wanting a little more than this? James
Instagram @suffolk_rovers
Post #592100 11th Jan 2017 1:11pm
TJ101
Thumbs Up That was one of the current thinking plans Inigo,, with a Thermo Top C,, Thanks for that
Chris, have the same but different make in the back of the rally van,, thinking wing tank and plumbed in system for shower etc
G-mack,, Usefull link,, Smile maybe Truma units on the large size ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #592101 11th Jan 2017 1:15pm
jst
that webasto heat exchanger could just be plumbed straight into engine coolant system then? so engine running or TermoTop running means hot water.
would need a 12v inline pump for the fresh water feed, ideally on demand a guess.
good thread Tim, need to sort this too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592286 11th Jan 2017 10:12pm
jst
http://www.gaelforcemarine.co.uk/en/Whale-...tedKingdom Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592299 11th Jan 2017 10:38pm
jst
http://www.hotcampshowers.com/vehicle_mounted_shower Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592302 11th Jan 2017 10:42pm
Stacey007
Our caravan Had a Truma water heater could you get some second hand bits from a caravan?
It also had a water storage unit, It wasn't that big from memory and worked very well.
https://www.truma.com/uk/en/water-systems/...ystems.php
Thanks
Post #592304 11th Jan 2017 10:45pm
jst
possible cheap solution, conventional heat exchanger from house boiler second hand plumbed with t pieces into engine coolant system.
whale submersible pump into jerry can to feed fresh water output through household std shower lead. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592307 11th Jan 2017 10:53pm
jst
you could connect up garden type hose fitting with spray gun for hot freshwater side of it?https://www.amazon.co.uk/Expandable-Pamper...&psc=1 Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592308 11th Jan 2017 10:54pm
jst
that webasto link doesnt show how its mounted or seem to have any mounting points showing?
laminova as a heat exchanger? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592310 11th Jan 2017 11:02pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
https://www.defender2.net/gallery/thumbnails.php?album=646
https://www.defender2.net/gallery/displayi...&pos=9 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #592335 12th Jan 2017 2:08am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I intend to add a heat shot heated wash jet system to a tank and pump. Won't give much just the same as washing your window but hopefully enough to was hands when out
Post #592545 12th Jan 2017 8:41pm
