Home > Maintenance & Modifications > Hot Running water in a 110 ? Whats the options
Page 2 of 2 <12
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Whale do a water heater that can be mounted under the vehicle:
http://www.propexleisure.co.uk/shop/whale-expanse-water-heater
It can also be mounted inside the vehicle, and contrary to the Truma, you do not have to mount it directly near the side of the car, because you can extend the flue (1m or more, I think) Defender 130 HCPU Td5 MY2000
Post #592736 13th Jan 2017 11:56am
jst
i have bitten the bullet and ordered a heat exchanger for the hot water system, just need to think it through now!
http://www.ebay.co.uk/itm/181480196765 Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #602439 16th Feb 2017 10:55pm
jst
Big thank you to Tatra for his help on this so far.
Question: does anyone know if you can have coolant running through a vehicle heat exchanger(HE) with the other side (shower side) of the HE empty and then add colder water without problem to the actual HE?
logic would say have a diverter to allow the coolant to bypass the HE when empty of shower water, well to me anyway.
dont want a cracked HE. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #604441 24th Feb 2017 11:11am
drinkdrinkdrop
I think something like this would be ideal
https://www.thermotion.com/4-port-electron...-354-69694
it's from the US though but the diagram give a good idea of what you might want. I think the Puma heater works the same way if I recall a previous post correctly
http://www.ebay.co.uk/itm/HEATER-CONTROL-V...2154277645
Though I can't seem to track down the wiring diagram to confirm, i've just started looking into doing a similar thing myself so keen to see how you get on
Post #604524 24th Feb 2017 3:43pm
jst
the puma heater only works if the heat is on yes in cold setting the coolant bypasses the heater. thank you for links will look. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #604574 24th Feb 2017 7:06pm
jst
just looked, yes works as per the first diagram on puma heater is my understanding
sop that ford puma/Kia one is similar then i take it? so would do same job? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #604576 24th Feb 2017 7:11pm
jst
after a great deal of thinking i started the install of mine today.
i purchased the heat exchanger with a jacket off ebay, it also came with a thermostatic mixing valve
http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
i used std plumbing fitting (its 1/2 and 3/4 BSP fitting on the HE) with barbs for the cold in (13mm) and coolant in/out 16mm.
http://www.ebay.co.uk/itm/262830364684?_tr...EBIDX%3AIT
http://www.ebay.co.uk/itm/321351921195?_tr...EBIDX%3AIT
pipework 16 & 13mm
http://www.ebay.co.uk/itm/331320582086?_tr...EBIDX%3AIT
I have currently mounted the pump - a shurflow 20psi 7l/min unit under the bonnet connected to the shower water in part. http://www.ebay.co.uk/itm/150991066980?_tr...EBIDX%3AIT its on demand, self priming, and can run dry and came with filter. the flow rate and pressure seem about right, this was the recommended one after speaking to as many people as i could!
The shower pipe/head out and water feed (pipe to water butt) are to be fitted when actually required.
Havent tested it fully yet and need to make a proper mount for the pump if its going to stay there. But its in and works - well i ran the websato for 8mins (the HE is plumbed into outlet from webasto) and it was hot enough to shower in Very Happy
Also need to get the vehicle upto temp to check coolant connections.
Pump supply to HE can be disconnected and blown through to make sure no water is left in the HE, having said that i am sure any water in it would evaporate with the coolant passing through the other side in it.
Shower is std house hold unit with pipe just added a ball valve to turn it on/off
http://www.ebay.co.uk/itm/231994285446?_tr...EBIDX%3AIT
Hope this of help to people thinking of doing the same thing. it took me 4hrs fitting including some thinking time! Space is the issue,Its all very tight in there! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #610102 17th Mar 2017 5:18pm
Page 2 of 2 <12
