Home > Puma (Tdci) > High speed vibration |
holmessato Member Since: 11 Mar 2010 Location: Milton Keynes Posts: 27 |
I get the same thing, but its at about 130kmh (limiter removed). I also get it when pushing the throttle hard in 6th gear (no other gear) from relatively low revs (about) 1500 revs. The vibration wont stop until lifting off and the re-applying applying throttle more gently. I think its too much backlash in the rear diff. I need to take the prop off and look in more detail. another one of those tasks for the dry weekend, that never comes!
20th Jan 2011 9:06pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2432 |
Probably a loosen UJ Puma 110" SW
20th Jan 2011 9:14pm |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 |
Hello,
I had the same thing with my 200tdi but it has 300 000 km on the clock, I thought it was some gaps. But now with my Puma. I would like to know if it's normal or not. When I'm going downhill, I can hear the noise when decelerate or accelerate slowly. Tomorrow, I'll check the UJ. Thanks. |
20th Jan 2011 10:08pm |
