Home > Puma (Tdci) > High speed vibration
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Hello,
Need your lights again, Bow down
When I'm driving on the highmay at 100Km/h and more, I hear a vibration from transmition when I decelerate slowly.
I didn't make neither lift nor change on suspension.
I know that I'm not alone, if someone has a solution.
Thanks Thumbs Up
Post #54034 19th Jan 2011 9:56pm
holmessato
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I get the same thing, but its at about 130kmh (limiter removed). I also get it when pushing the throttle hard in 6th gear (no other gear) from relatively low revs (about) 1500 revs. The vibration wont stop until lifting off and the re-applying applying throttle more gently. I think its too much backlash in the rear diff. I need to take the prop off and look in more detail. another one of those tasks for the dry weekend, that never comes!
Post #54222 20th Jan 2011 9:06pm
MK
Probably a loosen UJ Puma 110" SW
Post #54224 20th Jan 2011 9:14pm
Apynala
Hello,
I had the same thing with my 200tdi but it has 300 000 km on the clock, I thought it was some gaps. But now with my Puma. Shocked
I would like to know if it's normal or not. When I'm going downhill, I can hear the noise when decelerate or accelerate slowly.
Tomorrow, I'll check the UJ.
Thanks.
Post #54247 20th Jan 2011 10:08pm
