Home > In Car Electronics > Cubby Box Switched Ignition Feed |
The obvious question is which model of Defender do you have. Chances are though that the answer is no and you'll have to run one from the dash area. Darren
6th Jan 2017 5:38pm |
justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167 |
2012 110 DC XS spec.
6th Jan 2017 5:54pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
The rear of the black fuse box under the drivers seat.
I'm pretty sure there is one there, but be sure to do some testing. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
6th Jan 2017 6:02pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
I fitted one of these http://www.nippynormans.com/fuse-panels/fu...fuse-panel under drivers seat and ran a fused wire from the battery
6th Jan 2017 6:09pm |
Hi all, I decided to splice into the cigarette lighter wire rather than messing with the fuse box wiring. All done and working.
7th Jan 2017 1:53pm |
