Home > In Car Electronics > Cubby Box Switched Ignition Feed
justinp
Hi Chaps,
I'm planning to fit a double USB socket in my cubby box, is there an accessible wire I can splice into under one of the front seats?
Thanks - Justin
Post #590748 6th Jan 2017 4:38pm
The obvious question is which model of Defender do you have. Chances are though that the answer is no and you'll have to run one from the dash area. Darren
Post #590772 6th Jan 2017 5:38pm
justinp
2012 110 DC XS spec.
Post #590779 6th Jan 2017 5:54pm
The rear of the black fuse box under the drivers seat.
I'm pretty sure there is one there, but be sure to do some testing. KEEP CALM AND Drill ON
Post #590784 6th Jan 2017 6:02pm
mick
I fitted one of these http://www.nippynormans.com/fuse-panels/fu...fuse-panel under drivers seat and ran a fused wire from the battery
Post #590786 6th Jan 2017 6:09pm
justinp
Hi all, I decided to splice into the cigarette lighter wire rather than messing with the fuse box wiring. All done and working.
Post #590978 7th Jan 2017 1:53pm
