Home > Td5 > MAF sensor
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
MAF sensor
Hi All.
Had a MAF sensor failure today, think it crept up on me. Total loss of power/acceleration, thought it was fuel filter to start with, but on disconnecting the sensor it was like I had another bunch of horses under the bonnet.
Question- apart from adjusting the fuel/air ratio what eles does it connect with and can I run without it over the holiday period, have a run from bristol down the M5 tommorow.
Volt meter reading of 0.02 volts at tick over , as per the test on BAS site
Edward
Post #587440 24th Dec 2016 6:28pm
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Yes you can run it but it will be lumpy
On a brighter note I have a brand new one sitting in my office
Duckworths do them for £120, yours for £100 including P&P
Post #587477 24th Dec 2016 9:00pm
EWS
Thank you for your kind offer, but will be ordering from BAS
https://secure.bellautoservices.co.uk/store/td5-air-flow-meter/
Edward
Post #587499 24th Dec 2016 10:17pm
simon67
Happy do it for £80 including p&p
Post #587505 24th Dec 2016 10:53pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Simon I'd be interested if not
Post #587506 24th Dec 2016 10:58pm
simon67
Jrule, if ews doesn't want it, it's yours
Still boxed and ready to go
Post #587508 24th Dec 2016 11:12pm
Loz2286
Can I have second dibs? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #587517 25th Dec 2016 1:05am
simon67
Just st waiting on EWS
Post #587566 25th Dec 2016 1:59pm
EWS
Hi Simon.
Let it go, thanks for the kind offer.
Edward
Post #587599 25th Dec 2016 9:22pm
Screbble
All, apologies for the resurrection....
Hope you had a nice Christmas.
Did you sort it EWS?
Picking up on this info:
The diagram suggests testing for the approx 2vdc idling output at Pin 3 whilst the text states Pin 2.
Can anyone please confirm? Bow down
Happy New Year to one and all.
Post #588920 31st Dec 2016 9:27am
EWS
Hi Screbble.
Still running with MAF unpluged, have not noticed any problems, drives like it should . Have a cheapo one in the spares box just have not got round to fitting it, will purchase a VDO one in the next day or so.
Just pull the plug and tuck it away and run with out it, you should notice the difference, in my case it was an .
amazing increase in performance.
Pin 2 is the feed out and pin 3 the ground, so I understand.
I pushed dress making pins through the insulation to get a reading, to clip on the voltmeter.
Somewhere on here is a post from Dorsetsmith, explaining the workings , seen it today but cant seem to find it again.
Edward
Edit
Just found it, look down this post, read Dorsetsmiths post, good reading
http://www.defender2.net/forum/topic41695....maf+sensor
Post #589031 31st Dec 2016 6:24pm
