![]() | Home > Puma (Tdci) > Grease for UJ's |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Hi Lad's
Anyone got a manual at hand and can give me the type of grease for the prop shaft / UJ's? Thanks in advance. James p.s I managed to buy a relatively cheap little hand held grease gun to reach the front prop shaft grease nipples which are placed such that the fitting on the end of the normal grease gun cannot reach. Puma 110 - gone Series III 1973 - going strong |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Lubricants for drivetrain:
Engine Transmission Castrol BOT 130M 2.4 liters 5.1 US pints Transfer Box Castrol Syntrax 75W-90 or Texaco Multigear 75W-90R 2.3 liters 4.8 US pints Front Differential Castrol EPX 80W-90 or Texaco Geartex EP85W-90 1.6 liters 3.4 US pints Rear Differential Castrol EPX 80W-90 or Texaco Geartex EP85W-90 1.6 liters 3.4 US pints Sorry but the grease to be used in the UJ are not specified in the workshop manual ![]() If can help, transmission uses Grease ESD-M1C220-A Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Any high temperature grease will do - Graphite loaded is probably best.
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Curious, but why a high temp grease? I've always used an NLGI No.2 Lithium or Lime based grease.
Had to turn two of my U/Jgrease nipples to get the gun to fit. Don't forget the two sliding joints! I found "little and often" seems to work best (grease in, crap out). Bosun. |
Thanks all. Puma 110 - gone
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
I've had many problems finding the right solution to greasing the props but the one that works using a standard grease nipple adaptor is to:
1. jack all wheels off the ground 2. Place the centre diff in neutral This allows the shafts to be turned independently allowing you to find the best position to attach the grease gun. Hope this Helps Rich, ![]() |
This is the smaller gun compared to normal head
![]() ![]() Click image to enlarge don't think this grease will do though? ![]() Series III 1973 - going strong |
I've never come apon a lithium grease that wasn't 'high temperature' - will do OK |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5086 ![]() ![]() ![]() |
got some in a spray can from Halfrauds good stuff Mike
