Home > In Car Electronics > Improving Main Beam by Adding Dipped
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Is there a reason for not wiring up the dipped to come on with the main? I can see it may get a bit warmer.
I was thinking of going down the relay upgrade route but wondered if I should plan to add this into the upgrade.
Post #586170 18th Dec 2016 7:56pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
My guess is the bulb would overheat causing both filaments to fail.
Post #586173 18th Dec 2016 8:05pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
With a normal H4 bulb you will shorten the life of the bulb - probably drastically. If, however, you have LED headlights then some of them (Nolden and J W Speaker EVO I and II I know of) will switch off dipped beam once main is selected - the internal electronics inside the headlights prevent both.
Some other LED headlights may allow this - I know Vision X headlights will and in fact they produce a small harness to enable this.
With my Nolden headlights i feel that it wouldn't make too much difference anyway, but the main beam could be better, especially in the wet. I'm pondering putting a 20" or 21" LED light bar behind the lower grille. I have the Adventure-spec front grille and the lower part is much more open that the standard one and it's giving me some ideas to make use of it. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #586175 18th Dec 2016 8:11pm
miker
Running both filaments on a h4 bulb will overheat it rapidly. Redoing the loom with relays will help, and adding a couple of driving lights on the front bumper is also a good easy option.
Post #586181 18th Dec 2016 8:17pm
JustFX
I have some nice driving lights to wire up so it is in progress. I was merely speculating as to why it isn't a standard Mod.
Post #586186 18th Dec 2016 8:26pm
Procta
I use nightbreaker light bulbs on my 306 and that makes a massive difference so a good quality light bulb is a must, and good set of lights too. I bought my dad a pair of new head lights with nightbreaker bulbs and I tell you what he loves it!
I bought him a pair of dip and full beam spots too, so the front end is pure hardcore for lighting up the full works!
Post #586222 18th Dec 2016 9:24pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I'm running Wipac crystals, with Osram nightbreakers and a 20 inch LED lightbar... Fantastic on the country lanes at home.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #586436 19th Dec 2016 9:37pm
