Home > In Car Electronics > Improving Main Beam by Adding Dipped |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
Is there a reason for not wiring up the dipped to come on with the main? I can see it may get a bit warmer.
I was thinking of going down the relay upgrade route but wondered if I should plan to add this into the upgrade. |
18th Dec 2016 7:56pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
My guess is the bulb would overheat causing both filaments to fail.
18th Dec 2016 8:05pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1767 |
Running both filaments on a h4 bulb will overheat it rapidly. Redoing the loom with relays will help, and adding a couple of driving lights on the front bumper is also a good easy option.
18th Dec 2016 8:17pm |
I have some nice driving lights to wire up so it is in progress. I was merely speculating as to why it isn't a standard Mod.
18th Dec 2016 8:26pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5212 |
I use nightbreaker light bulbs on my 306 and that makes a massive difference so a good quality light bulb is a must, and good set of lights too. I bought my dad a pair of new head lights with nightbreaker bulbs and I tell you what he loves it!
I bought him a pair of dip and full beam spots too, so the front end is pure hardcore for lighting up the full works! |
18th Dec 2016 9:24pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
I'm running Wipac crystals, with Osram nightbreakers and a 20 inch LED lightbar... Fantastic on the country lanes at home.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
19th Dec 2016 9:37pm |
