Home > Technical > Were to tap the high beam headlight cable
Eduardo
Hi there.
My last question before to go...
I have a doubt about were is more easy to tap the high beam head light cable to connect the roof rack auxiliary beams. Any thoughts?
Eduardo Eduardo
Post #53427 17th Jan 2011 1:07pm
The Boy
This might help and to save me writing it all out again the link below.
http://www.landroveraddict.com/smf/index.php?topic=383967.0
HTH
Boy
Post #53435 17th Jan 2011 1:42pm
Glynparry25
Land Rover kit is via the back of the instrument cluster:
Using one of these , connect your trigger wire to Blue/Orange wire (or Blue/Slate wirwe for LHD)
Glyn Sheep
Post #53470 17th Jan 2011 5:31pm
Merlin
I picked it up from behind the headllight as it's an easy place to get to the wiring. From there you can run a wire to the battery box and fit the relays in there. To get the wires to the dash, go out through the battery box and then up by the seat, then under the carpet and pull it up the dash using a piece of wire.
Keeps the buldhead water tight. Hope that helps.
Merlin
Post #60280 20th Feb 2011 9:51pm
ian3583
Scotch locks are the devil's spawn - don't use them!
I own a mobile communications company I wouldn't let them on my premises. 2009 110 XS
1984 V8 90 CSW
1981 S3 Airportable
1981 101 GS
www.landrover-club.com
Post #60640 22nd Feb 2011 9:20pm
mse
They really aren't...but it's a really common (mainly on LR forums) miss conception!
I would say you shouldn't use them in really harsh external environments with no protection...and I wouldn't run huge voltages through them. Also there are other ways to join wires
But 12 years on and those I've used is fine Thumbs Up Mike
Post #60646 22nd Feb 2011 9:28pm
PaulMc
My preference is to tap the Blue/White wire from the back of the Dip/Main Beam Switch.
Also convenient, if you're using a dash mounted switch to isolate the driving lamps/roof rack lights, as you can easily put the switch in the trigger wire.
. Paul.
Post #60771 23rd Feb 2011 3:59pm
