Home > Technical > Were to tap the high beam headlight cable |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Hi there.
My last question before to go... I have a doubt about were is more easy to tap the high beam head light cable to connect the roof rack auxiliary beams. Any thoughts? Cheers Eduardo Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
17th Jan 2011 2:07pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
This might help and to save me writing it all out again the link below.
http://www.landroveraddict.com/smf/index.php?topic=383967.0 HTH Boy |
17th Jan 2011 2:42pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
I picked it up from behind the headllight as it's an easy place to get to the wiring. From there you can run a wire to the battery box and fit the relays in there. To get the wires to the dash, go out through the battery box and then up by the seat, then under the carpet and pull it up the dash using a piece of wire.
Keeps the buldhead water tight. Hope that helps. Merlin |
20th Feb 2011 10:51pm |
ian3583 Member Since: 19 Apr 2010 Location: Belfast Posts: 16 |
Scotch locks are the devil's spawn - don't use them!
I own a mobile communications company I wouldn't let them on my premises. 2009 110 XS 1984 V8 90 CSW 1981 S3 Airportable 1981 101 GS www.landrover-club.com |
22nd Feb 2011 10:20pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
They really aren't...but it's a really common (mainly on LR forums) miss conception! I would say you shouldn't use them in really harsh external environments with no protection...and I wouldn't run huge voltages through them. Also there are other ways to join wires But 12 years on and those I've used is fine Mike |
22nd Feb 2011 10:28pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 |
My preference is to tap the Blue/White wire from the back of the Dip/Main Beam Switch.
Also convenient, if you're using a dash mounted switch to isolate the driving lamps/roof rack lights, as you can easily put the switch in the trigger wire. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
23rd Feb 2011 4:59pm |
