Home > Puma (Tdci) > Engine gone
snapperspike
Engine gone
Hi guys, new to the forum, so Hi to all.
Big problem !
Our 2008 110 county with 90k miles has seized.
We are being told and quoted all sorts of crazy prices to replace the engine.
Soooooooo :-
Will the transit 115bhp or 140bhp fit as a replacement, if the flywheel is changed to solid, and the sump used off our engine ??
Has anyone actually DONE this ?
The reason is, that we are being told that you can"t get parts for the 2.4 tdci engine, and that it will be around £6k to replace the engine !
Extremely fed up, and cannot believe the things we are being told.
ANY advice and suggestions would be very welcome.
Spike
Post #586104 18th Dec 2016 3:49pm
LR90XS2011
you will get a good 2.4 loads cheaper than that Google is your friend DEFENDER 90 TDCI XS,
Post #586114 18th Dec 2016 4:50pm
Stacey007
Hello
As above quick google fins this...
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...SwstxVUyJu
£2500 fitted with warranty no idea is that is good but at least its a guide, Good luck
Post #586117 18th Dec 2016 4:56pm
g-mack
saved you £1300 already! and these guys have great reputation!
http://www.turnerengineering.co.uk/PBSCPro...ApYo8P8HAQ My 109 thread
my youtube channel
Post #586118 18th Dec 2016 4:57pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
Hi
Have you had the car since new? I am very surprised that an engine has gone after 90k miles, is there a possibility that it was clocked ?
Post #586124 18th Dec 2016 5:19pm
Froglaise
Re: Engine gone
Is it made of gold or something?
You have all the ancillaries and Defender specific parts already - you basically just need the block and head. I've swapped out much more complicated engines that this. Can't see how labour could get anywhere near to covering the rest.
Post #586126 18th Dec 2016 5:25pm
mk1collector
Could it be the oil pump failure with the recall? If it was Landrover might contribute Ray
My build thread
Post #586129 18th Dec 2016 5:43pm
snapperspike
Hi guys, thanks for all replies.
Yup, hsd the vehicle from new.
Your not as suprised as we are !!!
We've been told that parts are unobtainium for the 2.4, which I find hard to believe.
The £6K quote is including fitting vat etc, so an engine at £4K + would make it about right.
What is more puzzling, is that we can get a short, guarenteed transit engine for £1100 !!
I have yet to have a phone around on Monday, but as I said, as far as I can find out at the moment, the difference between the trannie engine and the defender engine, seems to be the flywheel, the sump, and possibly immobiliser and/or ecu.
Seems crazy to me !!
Thanks again for the posts.
Merry bleedin' Xmas !!!! Laughing
Post #586135 18th Dec 2016 6:02pm
I know the customer relations section has been quiet recently but you should try a post there & see what the official line is regarding their obligation to support a model for 10 years.
Post #586140 18th Dec 2016 6:27pm
Froglaise
Which parts are they talking about? If parts were that hard then Ford would have trouble with an awful lot of transit drivers! They were in production to 2011 and Ford follows the 10yr code of conduct on parts.
Post #586141 18th Dec 2016 6:28pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
I once looked into parts availability on the 2.4 years ago and don't know if anything has changed. However at the time I came to the conclusion it was a throw away engine. Things like oversize pistons were not available from Ford. I do recall though that land rover offered more engine parts but at a premium price.
Ford / landrover would argue that they are still supporting the vehicle as they will happily sell you a new engine.
Jono
Post #586383 19th Dec 2016 6:06pm
Snatch
United Kingdom 2000 Defender 90 Td5 PU Baltic Blue
I have had 3 transit engine go now. All repaired on warranty
Known oil pump / recall fault as suggested.
Post #586426 19th Dec 2016 8:58pm
Jonno
I can see me needing to re engine my defender at some point. I think the car will easily outlast the engine and with the Puma not being as rebuild friendly as engines from the past, something else might have to be dropped in.
However getting the instrument cluster to work with another ecu would again be a huge issue.
The Defender Puma is an odd vehicle it has many repairable elements like cars from the past, however the engine and ecu / electronics are as disposable as any.
Jonno
Post #586469 20th Dec 2016 12:50am
Froglaise
A friend and I have been playing with a instrument cluster, trying to get it to work with different immobilisers/ecu and we've discovered it is possible with a third party fully programmable ECU. Actually the DPF sensor input gave more trouble than the immobiliser (simple to code in) as it turned out.
When it comes to a full engine change to a different unit entirely, which I think you are right will happen at some stage, then going that route with the ECU would be the best option if more expensive. Also gives some extra tuning options.
Hopefully though, it's a good 10 or 15yrs before I need worry that much about it!
Post #586514 20th Dec 2016 11:07am
Snatch
I had a stroked 7.1 LS3 corvette engine in my BMW
Z3. I ran an emerald ECU on that car, very easy to tune .👍
Post #586518 20th Dec 2016 12:01pm
