Home > In Car Electronics > Radio problem
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
Radio problem
My kenwood radio that is fitted to my 300 tdi has this annoying problem that every now and then it will lose the station I am listening to and retune to another station ( usually classic fm) is this likely to be a fault with the radio or an Ariel problem my Ariel is just the little flexi rubber one the stations are all clear when listening to them
Post #585877 17th Dec 2016 8:05pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
It is probably that short antenna, had to replace mine with a standard telescopic one and reception is now great. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #586091 18th Dec 2016 2:50pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
It is a while since I had a Kenwood so hope my recollection is correct.
If you don't want to change aerials then you should alter the settings on the radio. You probably have AFC (automatic frequency control) set to on. This finds the next strongest signal when in a poor reception area. Switching it off will stop the radio searching, but you will lose/ have poor reception until you reach a better signal.
Post #586138 18th Dec 2016 6:07pm
