Home > Puma (Tdci) > Tdci trouble
Sam6830
England 2010 Defender 90 Puma 2.4 HT Tonga Green
Tdci trouble
Hi all.
I'm having trouble with my 2010 defender tdci, its using coolant and blowing hot and cold out of the heater. It's had a new thermostat, water pump, water cap and heater valve. It's had the radiator and all the water pipes blown out then coolant put back in and re bleed numerous times yet it is still happening. I've had it pressure tested and head gaskets test a few times and all seems fine. Sort of running out of ideas now without taking the engine apart.
If anyone could help that would be great?
Post #585660 16th Dec 2016 8:54pm
dgardel
Italy
Check the EGR exhaust gas cooler Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #586007 18th Dec 2016 9:47am
