Home > Technical > Cold start TD5
Deondef
South Africa
Cold start TD5
My TD5 battles more and more to start on cold mornings. Is the only cause suspect glow plugs or can there be any other cause. Once it has started it is fine - no excessive smoke, etc. Defender TD5 110 CSW 2000 British Racing Green (what 's remaining between scratches).
Snorkel, extra fuel tank, water tank, double batteries, winch, spots
Post #270 13th Jul 2007 6:37am
Herman
Mine did the same, it was fixed by replacing the ECU (still under warranty)
Post #274 14th Jul 2007 10:48am
heine
South Africa 1997 Defender 110 2.8i Petrol CSW Alpine White
Deon you must be getting pretty Banging Head with Land Rover at the moment
Post #277 16th Jul 2007 9:18am
Deondef
South Africa
Heine - my Defender is like my pets, children, wife, etc - I know it inside out.
I KNOW that it will not fail me if I attend to early warning signs early enough. The early morning starts is just an irritation - I have enough battery power (350 a/h) when 3rd battery box is attached to "drive" me on starter motor to closest downhill to run start !!!!!!!!!!!!!! Defender TD5 110 CSW 2000 British Racing Green (what 's remaining between scratches).
Post #279 18th Jul 2007 4:38pm
heine
Yup - likewise - it may have a million niggles and noises , but I know what each one means
Post #281 19th Jul 2007 8:59am
