![]() | Home > Technical > Nato Hitch fixings |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
My bolts are purchased from a local bolt supplier on an industrial estate. Tend to get BZP ones. 1999 Defender TD5 110
Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261 ![]() ![]() ![]() |
Thanks excossack we do have a local bolt specialist will see if any of the site sponsors sell them before I go local
Cheers again Lee |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
Make sure you get 8.8 grade or better. Believe that they are m12 yes
Thanks miker
I have just bought some 10.9 grade but M14 as they go through the body of the hitch and I am not fixing to the rear cross member so hopefully thats me moving forward now. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6138 ![]() ![]() ![]() |
Yes, M14 will just fit through the casing of the hitch.
I can't see that you'd particularly need HT ones with 14mm diameter, I think they'd be plenty strong enough! (as said, just make sure they're 8.8 at least. are 12. HT ones?) Your crossmember will be coming away before 4x M14 snap! |
8.8 is the minimum grade usually referred to as "Hugh tensile". Everything below that is usually 4.something cheese grade bolts.
Cheers guys
visions of the crossmember on the deck when I pull away ![]() ![]() ![]() Cant possibly get enough weight in a a penman can I ![]() ![]() |
progress is progress
![]() Click image to enlarge ![]() ![]() Click image to enlarge ![]() |
![]() Click image to enlarge Just need a trailer now ![]() |
I'm always surprised when I see things on FB then again on here
![]() Looks great, I'd say just about high enough ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3805 ![]() ![]() |
looks neat
![]() ![]() I took a while sorting my height out, the sankey is designed to run nose down and apparently rides better this way...l As I bought it... On the original location ![]() Click image to enlarge drop plated added ![]() Click image to enlarge new height ![]() ![]() Click image to enlarge |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
I have a standard ride height (new genuine springs) '07 110 SW with which I tow my Penman. I use a Nato hitch bolted directly to the crossmember as it would be fitted on any military 110, and it is as high as it is possible to get before fouling the spare wheel. I also run 7.50 x 16 military tyres and wheels. I found that mine tows significantly nose-down, although you don't feel that this causes a problem in its driving behaviour. I suspect it would need a 2-3 inch lift to level it up entirely if one felt that way inclined.
In case you change your mind, if you bolt directly to the crossmember you need high-tensile (at least 8.8 ) M12 bolts as it has thread inserts built in. The length will depend on if you use of a spreader plate between hitch and crossmember - I use an old dixon bate slider at the moment just to spread the load across the crossmember face as it isn't that strong with a side load and a relatively small mating face of the Nato hitch. The Penman is absolutely bulletproof. It has a payload of something over 2 tons but a loadbed only 5' x 6'. I reckon it is the toughest trailer I have seen and i've spent a couple of weeks at the Ifor Williams factory installing machinery. I think it will outlive me ![]() |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Slightly off topic Lee - but that is exactly the setup I'm looking for. I've currently got my towball attached directly to the rear NAS step, but having lifted the vehicle 2" its now too high for trailers. Your setup would extend it down by a few inches which is perfect. I presume that lower part under the ball is suitable for being recovered from? Can you tell me what that unit is called please, and any suggestions of where to get it from would be appreciated. |
Hi Hufflepuff,
I am unsure of the actual model of mine as the lLand rover dealer ship fitted it but the link here is the closest I have seen http://dixon-bate.co.uk/products/gb/132-height-adjusters Hope you get sorted out I think I will be having another front plate rolled and drilled 30 to 35 mm longer Cheers Lee |
