Home > Technical > Nato Hitch fixings
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Nato Hitch fixings
Hi Guys
I am looking for some advice and where to purchase high tensile bolts washers etc to fix my new nato hitch to the "C" section I have had made to extend the hight.
Are the bolts M12"
Below is my current set up and my new plate
Any help would be great
Lee
Post #583452 8th Dec 2016 11:06am
excossack
My bolts are purchased from a local bolt supplier on an industrial estate. Tend to get BZP ones. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #583455 8th Dec 2016 11:21am
Leeroy
Thanks excossack we do have a local bolt specialist will see if any of the site sponsors sell them before I go local
Cheers again
Lee
Post #583457 8th Dec 2016 11:35am
miker
Make sure you get 8.8 grade or better. Believe that they are m12 yes
Post #583477 8th Dec 2016 1:25pm
Leeroy
Thanks miker
I have just bought some 10.9 grade but M14 as they go through the body of the hitch and I am not fixing to the rear cross member so hopefully thats me moving forward now.
Post #583487 8th Dec 2016 2:29pm
Yes, M14 will just fit through the casing of the hitch.
I can't see that you'd particularly need HT ones with 14mm diameter, I think they'd be plenty strong enough! (as said, just make sure they're 8.8 at least. are 12. HT ones?)
Your crossmember will be coming away before 4x M14 snap!
Post #583530 8th Dec 2016 6:29pm
miker
8.8 is the minimum grade usually referred to as "Hugh tensile". Everything below that is usually 4.something cheese grade bolts.
Post #583532 8th Dec 2016 6:34pm
Leeroy
Cheers guys
visions of the crossmember on the deck when I pull away Rolling with laughter Rolling with laughter Rolling with laughter
Cant possibly get enough weight in a a penman can I Shocked Razz
Post #583635 9th Dec 2016 3:43am
Leeroy
progress is progress
Post #583756 9th Dec 2016 7:03pm
Leeroy
Just need a trailer now Rolling with laughter
Post #601841 14th Feb 2017 6:46pm
JOW240725
I'm always surprised when I see things on FB then again on here Thumbs Up
Looks great, I'd say just about high enough Thumbs Up Thumbs Up James
Instagram @suffolk_rovers
Post #601881 14th Feb 2017 8:36pm
Stacey007
looks neat Smile nice job Thumbs Up
I took a while sorting my height out, the sankey is designed to run nose down and apparently rides better this way...l
As I bought it... On the original location
drop plated added
new height Smile
Post #601891 14th Feb 2017 9:02pm
Thon
I have a standard ride height (new genuine springs) '07 110 SW with which I tow my Penman. I use a Nato hitch bolted directly to the crossmember as it would be fitted on any military 110, and it is as high as it is possible to get before fouling the spare wheel. I also run 7.50 x 16 military tyres and wheels. I found that mine tows significantly nose-down, although you don't feel that this causes a problem in its driving behaviour. I suspect it would need a 2-3 inch lift to level it up entirely if one felt that way inclined.
In case you change your mind, if you bolt directly to the crossmember you need high-tensile (at least 8.8 ) M12 bolts as it has thread inserts built in. The length will depend on if you use of a spreader plate between hitch and crossmember - I use an old dixon bate slider at the moment just to spread the load across the crossmember face as it isn't that strong with a side load and a relatively small mating face of the Nato hitch.
The Penman is absolutely bulletproof. It has a payload of something over 2 tons but a loadbed only 5' x 6'. I reckon it is the toughest trailer I have seen and i've spent a couple of weeks at the Ifor Williams factory installing machinery. I think it will outlive me Smile
Post #601899 14th Feb 2017 9:25pm
Hufflepuff
Re: Nato Hitch fixings
Leeroy wrote:
Slightly off topic Lee - but that is exactly the setup I'm looking for. I've currently got my towball attached directly to the rear NAS step, but having lifted the vehicle 2" its now too high for trailers. Your setup would extend it down by a few inches which is perfect. I presume that lower part under the ball is suitable for being recovered from?
Can you tell me what that unit is called please, and any suggestions of where to get it from would be appreciated.
Post #601977 15th Feb 2017 12:42pm
Leeroy
Hi Hufflepuff,
I am unsure of the actual model of mine as the lLand rover dealer ship fitted it but the link here is the closest I have seen
http://dixon-bate.co.uk/products/gb/132-height-adjusters
Hope you get sorted out
I think I will be having another front plate rolled and drilled 30 to 35 mm longer
Lee
Post #602078 15th Feb 2017 8:11pm
