Home > Puma (Tdci) > Think a UJ has failed |
Luis33 Member Since: 30 Nov 2016 Location: Hants Posts: 2 |
Hi Guys,
I'm new to the landy world and I think I have a problem with a UJ on the driveshaft. I've taken a sound clip if anyone has had this problem before, Please help!! http://vocaroo.com/i/s0hx3zSlMUkn |
30th Nov 2016 3:01pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
If you want to rule things out, you can remove the prop shaft, put the transfer box in to diff lock and drive around in 2WD for a bit. The axle differential will still be going round (driven by the wheels) but you won't have the prop shaft to make funny noises.
1st Dec 2016 1:03pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
It sounds like a UJ to me. But as the previous poster says remove each propshaft in turn and test it again. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
2nd Dec 2016 9:17am |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
You don't need to remove the props to check UJs.
Simply chock the vehicle on flat ground, leave handbrake off and gears in neutral, then you can get underneath and check for play in the joints by grasping the prop in one hand and the drive flange on the diff or transfer case in the other and twist them opposing directions - you should then see if there is any relative movement in the joint itself. If there is then it needs replacing. Then you need to take the prop(s) off. |
2nd Dec 2016 12:05pm |
Thanks for the reply guys. Had it fixed, Was one of the front UJ's. So worn it F***ed the driveshaft also!
12th Dec 2016 11:59am |
