Home > Puma (Tdci) > Think a UJ has failed
Luis33
Hi Guys,
I'm new to the landy world and I think I have a problem with a UJ on the driveshaft.
I've taken a sound clip if anyone has had this problem before, Please help!!
http://vocaroo.com/i/s0hx3zSlMUkn
Post #581647 30th Nov 2016 3:01pm
Stacey007
Does it 'clonk' a little as you move slowly back wards and forwards?
When mine went and the engine was under load (accelerating or going up a hill) it sounded like a tin can was lose under the car.
Cheap and easy fix for the garage though.
Post #581678 30th Nov 2016 4:55pm
Cupboard
If you want to rule things out, you can remove the prop shaft, put the transfer box in to diff lock and drive around in 2WD for a bit. The axle differential will still be going round (driven by the wheels) but you won't have the prop shaft to make funny noises.
Post #581923 1st Dec 2016 1:03pm
nickhodgson
It sounds like a UJ to me. But as the previous poster says remove each propshaft in turn and test it again. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #582083 2nd Dec 2016 9:17am
Thon
You don't need to remove the props to check UJs.
Simply chock the vehicle on flat ground, leave handbrake off and gears in neutral, then you can get underneath and check for play in the joints by grasping the prop in one hand and the drive flange on the diff or transfer case in the other and twist them opposing directions - you should then see if there is any relative movement in the joint itself.
If there is then it needs replacing.
Then you need to take the prop(s) off.
Post #582145 2nd Dec 2016 12:05pm
Luis33
Thanks for the reply guys. Had it fixed, Was one of the front UJ's. So worn it F***ed the driveshaft also!
Post #584410 12th Dec 2016 11:59am
