Home > Puma (Tdci) > Need to mount 2 new switches |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
What type of switches? Defender style, or are you sourcing your own alteratives?
Meanwhile I just had a look at the mud console, was it the 'splat' logo? Solved the bowel problem, working on the consonants... |
29th Nov 2016 2:22am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Click image to enlarge http://www.defender2.net/forum/topic49880.html Or https://www.firstfour.co.uk/defender-double-switch-bezel.html Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
29th Nov 2016 7:06am |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Here was mine before I installed a double din
Click image to enlarge I think it looked very neat, easily accessible- See mcma1 for the switch surround I think a bit cheaper than first four 2020 P300 HSE |
29th Nov 2016 7:26am |
Moles Member Since: 17 Mar 2016 Location: Wiltshire Posts: 40 |
Looks like a neat solution.
I think at some point too I'll go double DIN, but not just yet, so this is a good stop gap. I'm assuming it's easy enough to cut the panel in situ? I've not had a look behind there for a while, but assume there's enough room etc. Cheers, Moles |
29th Nov 2016 3:41pm |
Enough room behind there to make it an easy job Solved the bowel problem, working on the consonants...
29th Nov 2016 4:52pm |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 273 |
Very neat solution , but why the additional fuel gauge ? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th Nov 2016 5:37pm |
For the second tank ??? Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
30th Nov 2016 12:22am |
Just a quick follow up.
What's the general opinion of RDX switches? Plus, anyone fitted a radio timer, i.e. where you can turn the radio on without the ignition on position 1, but it only stays on for 15 mins or so? I've seen a few units like this. Cheers, Moles |
5th Dec 2016 9:03pm |
RoyW Member Since: 30 Dec 2014 Location: Utrecht Posts: 9 |
I needed 4 switches and fitted these ones. They have a good seal against dust and moist.
The 2 on top have an on/off switch. The lowest panel has and switch for on/off and one is used for my winch. Click image to enlarge Click image to enlarge I bought them here: https://shop.landreiziger.nl/componenten/s...l-131.html |
6th Dec 2016 8:41am |
