Home > Puma (Tdci) > Need to mount 2 new switches
Moles
What the current thinking on the best way to mount a couple of extra switches on the Puma consol?
I'm not so keen on the look of the Mud Puma pod.
Cheers.
Moles.
Post #581230 28th Nov 2016 11:53pm
agentmulder
Kuwait
What type of switches? Defender style, or are you sourcing your own alteratives?
Meanwhile I just had a look at the mud console, was it the 'splat' logo? Solved the bowel problem, working on the consonants...
Post #581234 29th Nov 2016 2:22am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
http://www.defender2.net/forum/topic49880.html
Or
https://www.firstfour.co.uk/defender-double-switch-bezel.html
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #581247 29th Nov 2016 7:06am
pjb
Here was mine before I installed a double din
I think it looked very neat, easily accessible- See mcma1 for the switch surround I think a bit cheaper than first four Thumbs Up 2020 P300 HSE
Post #581251 29th Nov 2016 7:26am
Moles
Looks like a neat solution.
I think at some point too I'll go double DIN, but not just yet, so this is a good stop gap.
I'm assuming it's easy enough to cut the panel in situ? I've not had a look behind there for a while, but assume there's enough room etc.
Cheers,
Moles
Post #581324 29th Nov 2016 3:41pm
agentmulder
Kuwait
Enough room behind there to make it an easy job Thumbs Up Solved the bowel problem, working on the consonants...
Post #581349 29th Nov 2016 4:52pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Or
Very neat solution , but why the additional fuel gauge ?
Post #581360 29th Nov 2016 5:37pm
Theater
Outlaw1
For the second tank ??? Marco
Post #581492 30th Nov 2016 12:22am
Moles
Just a quick follow up.
What's the general opinion of RDX switches?
Plus, anyone fitted a radio timer, i.e. where you can turn the radio on without the ignition on position 1, but it only stays on for 15 mins or so? I've seen a few units like this.
Cheers,
Moles
Post #582948 5th Dec 2016 9:03pm
RoyW
Netherlands
I needed 4 switches and fitted these ones. They have a good seal against dust and moist.
The 2 on top have an on/off switch.
The lowest panel has and switch for on/off and one is used for my winch.
I bought them here:
https://shop.landreiziger.nl/componenten/s...l-131.html
Post #583017 6th Dec 2016 8:41am
