![]() | Home > Puma (Tdci) > irratic performance |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
You will have noticed the dpf doing its regen. Then many posts on here about it. The turbo opens fully up and the timing is changed.
A remap will make a massive difference. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 ![]() ![]() ![]() |
I've noticed the dpf doing a regen, normally just after a run on the motorway, the engine seems to roar even on tickover, i'd only done a couple of miles so I discounted this but I have to say the symptoms are similar, but it only sounded different when I moved off, it just felt so sharp, it made me think there has been something wrong with it all this time, i'll check some other threads thanks very much
yes, a quick look indicates the dpf was doing its regen, and yes i'm going for a remap I think BAS is the way to go
