Home > Puma (Tdci) > irratic performance |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
You will have noticed the dpf doing its regen. Then many posts on here about it. The turbo opens fully up and the timing is changed.
A remap will make a massive difference. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
26th Nov 2016 7:38pm |
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 |
I've noticed the dpf doing a regen, normally just after a run on the motorway, the engine seems to roar even on tickover, i'd only done a couple of miles so I discounted this but I have to say the symptoms are similar, but it only sounded different when I moved off, it just felt so sharp, it made me think there has been something wrong with it all this time, i'll check some other threads thanks very much
26th Nov 2016 7:56pm |
yes, a quick look indicates the dpf was doing its regen, and yes i'm going for a remap I think BAS is the way to go
26th Nov 2016 8:05pm |
