- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
yeldef
Hello,
I've got following problem :
When i several times put the led lazer on and off in a minute, then the 25A fuse melt..
I have a ST-8 hybrid beam, use a relais and have a glass fuse of 25A... the fuse holder and the fuse are completly melted into each other.. Normaly the current should be 7.16 A....
Is there a explanation on this ?
thx for the answers.
6th Nov 2016 7:28pm |
