Home > Maintenance & Modifications > Long Range Fuel tanks |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
Bumping an old thread here.
I am looking at what options I have for an '89 110 v8 with respect to larger fuel tanks. I cannot see a replacement main tank on the Safari-Equip site: http://www.safari-equip.co.uk/index.php/ta...cletype=12 so I'm not sure if they have stopped manufacturing them. I would have ideally liked a single main tank with a double skinned bottom for a bit of extra piece of mind, with capacity in the region of 110->120 litres, just to give the thirsty v8 a range similar to a diesel powered 110. I'm not a big fan of the rear arch tanks, as they look mighty fiddly to fit, you lose access to a potentially useful part of the vehicle to reach the underside of the tub and the rear electrics, and I would worry about larger wheels on a flexible suspension setup coming in contact. The metal tank on the current v8 is toast anyway, remarkable that its still able to actually hold fuel Also planning to get a Richards Chassis galvonized replacement chassis, and they offer the ability to fit the brackets for Td5 style fuel tanks, which might expand my options a little further, such as the "Long Ranger" ( https://www.devon4x4.com/tank-defender-all-except-td5-1.html ) although for some reason this says its only suitable for diesel models? 2005 Td5 90 XS 1989 V8 110 CSW |
12th Mar 2018 1:01pm |
