Home > In Car Electronics > Radio and USB Noise
AdamGT3
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
Radio and USB Noise
My radio reception is poor at best and has a flexible antenna replaced by the previous owner. Its a 2007 Puma and if I pug any power device into the cigarette lighter I just get hiss. Lower power devices hiss with some sound.
Is there something badly wrong or do I just need a suppressor? It has the original land rover stereo.
Thanks
Adam
Post #574269 29th Oct 2016 9:11pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
The noise may be exaggerated by not having a good signal to start with. That's the problem I had with a previous vehicle.
I did read on Amazon that some makes of lighter to USB psu's can cause interference so its best to read the reviews.
I went for an "Anker" make but this didn't make good connection with the socket so had to swap it. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #574286 29th Oct 2016 10:38pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
I get the same with my dash cam plugged in ,just as well I don't listen to it that much.
Post #574299 30th Oct 2016 7:02am
Rashers
Had the same issue with a plugin usb adaptor I got from Amazon. Plug in, radio poor, plug out, radio normal. I did manage to buy another which is ok and doesn't cause any noise. But selection is hit and miss. As a rule of thumb, the smaller adaptors and el-cheapo cigarette lighter chargers seem to be the worse. Probably due to a lack of suppression?
Post #574303 30th Oct 2016 7:38am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Re: Radio and USB Noise
Thanks
Adam
Here is a linky to what I did on my Pumas secondary power socket...
http://www.defender2.net/forum/topic26844.html ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #575071 2nd Nov 2016 11:26pm
excossack
I have the same but with a Blue Sea USB socket. Cheaper Ebay dual USB ones that go into a cigarette socket are fine. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #575499 4th Nov 2016 6:58pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I also have the same problem and when I try to charge my phone or Tom Tom it gets very hot.
I have to keep charging stuff on it .
Is there a make that wont do this?
Thank you
Fabio
Post #575781 6th Nov 2016 10:21am
excossack
I use a Griffin one http://www.ebay.co.uk/itm/dual-twin-port-U...Sw~bFWPSla
and I have one of these http://www.ebay.co.uk/itm/DC12V-24V-Car-4-...SwgmJXzWL8 1999 Defender TD5 110
Regards
John M0VAZ
Post #575912 6th Nov 2016 8:04pm
