Home > In Car Electronics > Radio and USB Noise |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
The noise may be exaggerated by not having a good signal to start with. That's the problem I had with a previous vehicle.
I did read on Amazon that some makes of lighter to USB psu's can cause interference so its best to read the reviews. I went for an "Anker" make but this didn't make good connection with the socket so had to swap it. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
29th Oct 2016 10:38pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
I get the same with my dash cam plugged in ,just as well I don't listen to it that much.
30th Oct 2016 7:02am |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3539 |
Had the same issue with a plugin usb adaptor I got from Amazon. Plug in, radio poor, plug out, radio normal. I did manage to buy another which is ok and doesn't cause any noise. But selection is hit and miss. As a rule of thumb, the smaller adaptors and el-cheapo cigarette lighter chargers seem to be the worse. Probably due to a lack of suppression?
30th Oct 2016 7:38am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Here is a linky to what I did on my Pumas secondary power socket... http://www.defender2.net/forum/topic26844.html ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
2nd Nov 2016 11:26pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5881 |
I have the same but with a Blue Sea USB socket. Cheaper Ebay dual USB ones that go into a cigarette socket are fine. 1999 Defender TD5 110
4th Nov 2016 6:58pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
I also have the same problem and when I try to charge my phone or Tom Tom it gets very hot.
I have to keep charging stuff on it . Is there a make that wont do this? Thank you Fabio |
6th Nov 2016 10:21am |
I use a Griffin one http://www.ebay.co.uk/itm/dual-twin-port-U...Sw~bFWPSla
and I have one of these http://www.ebay.co.uk/itm/DC12V-24V-Car-4-...SwgmJXzWL8 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
6th Nov 2016 8:04pm |
