Home > Puma (Tdci) > Just doing same test......
dgardel
Italy
Perfect interactions from timer and remote!!!!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #51910 9th Jan 2011 1:13am
Naks
o_O
what test is this?
Post #51911 9th Jan 2011 6:01am
wyvern
...... Dgardel - I know you're Italian but this looks like a lot of Spagettii!! Whistle
What are you playing with ?? Embarassed Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #51913 9th Jan 2011 6:47am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
think the clue's in the Webasto timer and wiring harness .................
Post #51918 9th Jan 2011 8:26am
dgardel
Italy
Yesssss
tested the "integrations" from Timer and remote control for the Webasto water Heater and all tests was OK
1. you can switch on from the timer and switch off from the timer
2. you can switch on from the timer and switch off from the remote
3. you can switch on from the remote and switch off from the timer
4. you can switch on from the remote and switch off from the remote
5. you can switch on from the remote and the timer switch off when the operating time is finished
6. you can switch on from the timer and the timer switch off when the operating time is finished
you can set the operating time from 2 to 120 minutes Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #51968 9th Jan 2011 2:05pm
