Home > Tdi > Low fuel light
Low fuel light
Anybody know how this is triggered? Mine seems to come on randomly so I need to do a bit of fault finding.
Oh, and yes it has got fuel in it! Filled it up yesterday and light went out. Started it today and light came on again Rolling Eyes Darren
Post #572677 22nd Oct 2016 4:42pm
Retroanaconda
Usually there is a third spade connector on the fuel level sender that triggers the light based on level. A wire from that to the light is the usual setup.
However some models have a small printed circuit board taped up in the loom that interprets the fuel level signal and controls the light, to which it is connected. Mine (1992) had that, but I ripped it out when I converted to Td5 clocks.
Post #572679 22nd Oct 2016 4:48pm
Ah, thanks for that. Mines a '92 as well and there are only two wires to the tank sender, which suggests other electrickery at work. I've had all of the dash in bits, so it could just be a duff connection somewhere, but I'd like to narrow it down a bit.
Where abouts in the loom should I be looking for the circuit? Darren
Post #572686 22nd Oct 2016 5:18pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
I await developments with interest as mine has never worked. You are giving me some
Places to check. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #572688 22nd Oct 2016 5:25pm
Retroanaconda
If I recall correctly the PCB wotsit was behind the clocks somewhere.
Try following the wire from the low fuel light itself back into the loom if you can.
Post #572698 22nd Oct 2016 5:51pm
Ok, thanks, I'll take a look.
Ironically, I may have accidentally found the problem though. Just been out for a run (fish & chips Cool ) and I had trouble starting it. Turn the key to start and it would fire but die as the key was released from the start position. All of the dash lights died, too. However, a bit of key jiggling and it started straight away, which tells me that the ignition switch is worn. Given the way that the fuel light seems to reset after starting, it may be related.
Anyway, fitting a new ignition switch is now in my future. Darren
Post #572706 22nd Oct 2016 6:37pm
