![]() | Home > Technical > Rear noise/vibration Defender 90 |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Does sound a bit like it is labouring i.e. in too high a gear causing the prop shaft is "flex". I have the R380 gearbox fitted to a 96 300 Tdi and find it difficult to get into 5th unless at speeds of 50+(on motorways etc) otherwise it labours and produces a similar noise. Jeff
Bluebar Member Since: 08 Jun 2016 Location: Bucks Posts: 10 ![]() ![]() |
If your noise/vibration turns out to be prophaft related, I have used a company in Feltham Middlesex in past years and they were reliable and efficient, close to M25 junc 14.
I have no connection with them other than as a customer. They're called Propshaft Services they make, repair and balance propshafts of all descriptions. Tel. 08443348655 Hope this helps. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8207 ![]() ![]() ![]() |
Prop UJs Cheers
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
Hi JCP
Did you get to the bottom of this? I have the same thing. All my underneath has been rebuilt, i can't find any movement in the UJ's and I've had my wheels balanced. Thanks Julia |
