Home > In Car Electronics > Best place to site extra relays around the dash?
Welkman
Hello,
I need to fit two relays for my electric windows somewhere behind the dash. Any ideas? There does not seem to be too much space in there. I have toyed with mounting them in the engine bay but this would obviously lead to complications with water ingress etc.
Any tips gratefully received.
James
Post #566532 25th Sep 2016 5:43pm
Romadog
You dont say what vehicle you have but assuming Td5 and previous then put them with others on fuse panel infront of gear levers
Post #566537 25th Sep 2016 5:56pm
Welkman
yep it is td5. I will have to see if there is enough space there, it looks fairly full.
Post #566540 25th Sep 2016 6:00pm
VeeTee
Netherlands
Seatbox? Cheers, Vincent
MySite
Post #566542 25th Sep 2016 6:06pm
Welkman
Auxiliary fusebox is on the bulkhead behind the passengers seat with live feeds run through conduit to the bulkhead so the ideal place is near the dash or the engine bay.
Post #566544 25th Sep 2016 6:14pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have 4 relays situated behind the speaker on the passengers side on the dash on my Td5
Easy to access the wires - just unscrew the speaker
Closer than the seat box to run wires to centre of Dash for switches etc
Post #566547 25th Sep 2016 6:18pm
Welkman
I like that plan! I think I have been over complicating my electric window install anyway. It is a 6 feed switch that reverses polarity so I think it just needs feeding from one ignition switched relay and the switches themselves have the full load running through them.
Post #566769 26th Sep 2016 6:12pm
