![]() | Home > In Car Electronics > Best place to site extra relays around the dash? |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
You dont say what vehicle you have but assuming Td5 and previous then put them with others on fuse panel infront of gear levers
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 ![]() ![]() |
yep it is td5. I will have to see if there is enough space there, it looks fairly full.
Seatbox? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Auxiliary fusebox is on the bulkhead behind the passengers seat with live feeds run through conduit to the bulkhead so the ideal place is near the dash or the engine bay.
boode Member Since: 11 Apr 2012 Location: Devon Posts: 434 ![]() ![]() ![]() |
I have 4 relays situated behind the speaker on the passengers side on the dash on my Td5
Easy to access the wires - just unscrew the speaker Closer than the seat box to run wires to centre of Dash for switches etc |
I like that plan! I think I have been over complicating my electric window install anyway. It is a 6 feed switch that reverses polarity so I think it just needs feeding from one ignition switched relay and the switches themselves have the full load running through them.
