Home > Technical > Electrical Schematic Required
AndyLincs
Landrover defender 2012 Puma
Blowing 5Amp fuse controlling many functions on dash and putting engine into limp mode.
Dip beam/windows/dash instruments all not working...
Need to trace what this fuse is supplying to check for shorts etc.
Very intermittent can go days without blowing and then can blow three or four times in a row.
Anybody have access to a schematic for this model ?
Post #565843 22nd Sep 2016 6:51pm
Sounds like a short that is possibly chaffing on something hence the intermittent issue.
Will need tracing as soon as possible.
Check the rubber boots body to doors for frayed, chafed wires too. $W33T $0U7H3RN $UG4R
Post #565847 22nd Sep 2016 6:58pm
AndyLincs
Yep sounds that way to me, I will check that location thanks
Not my truck but a mates who is dropping it off to me on Sat to have a look but unsure atm to what this fuse feeds hence needing a schematic
Post #565854 22nd Sep 2016 7:05pm
K9F
Click on the 'workshop' icon.
http://api.viglink.com/api/click?format=go...52F1523pV3 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #565855 22nd Sep 2016 7:10pm
AndyLincs
K9F Thank you very much
Post #565860 22nd Sep 2016 7:22pm
Off Topic Mal. (K9F) - Interesting article on that link you posted about Nolden LED headlights. Thumbs Up $W33T $0U7H3RN $UG4R
Post #565867 22nd Sep 2016 7:31pm
