Home > Technical > Puma Heater
pjh
Puma Heater
Happy New Year All!
The heater on my 07MY Puma is positively volcanic in its output and with a significant difference in temperature between the passenger and drivers side (drivers side runs cooler) when on mid-setting. It doesn't seem to run much cooler until the dial is well into the blue area and then there is a significant temperature drop.
The temperature gauge reading is normal and the coolant level in the expansion tank is fine.
Is it just a Defender foible or something to worry about?
Many thanks,
Peter Defender 11MY USW
Post #50622 1st Jan 2011 5:21pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I think there is a known problem with the heater that makes it do that, im sure somebody whos had it fixed will be alone soon!
Pete.
Post #50626 1st Jan 2011 5:30pm
shingwell
There is a fix somewhere on here for heater output difference - do a search - which involves removing the heater matrix and covering part of it in aluminium foil.
My dealer measured a difference of 2C between the passenger and drivers side on mine, and then measured several other Pumas and found them all to exhibit the same problem
I haven't actually tried the fix yet myself (can't be arsed to remove the heater matrix atm) but it causes problems for me (driver) and mrs (passenger) as she notices the cold quicker then me anyway - if the problem was the other way round it would be a definite positive feature!
Post #50654 1st Jan 2011 9:35pm
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Yes, it's a Defender foible!
But have an instruction named: "Heater Core Combing Process", I have it buto don't know how to post it.
Mine do the same, but the drivers side is hotter (because its left hand), I didn't do this "process" and don't know if it works 100%.
It's another Land Rover thing!!!
cheers
Post #51035 4th Jan 2011 7:10pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I have been wondering if there is anyway of slowing the fan down a bit more even on no 1it seems fast what controls the fan speed is it a relay.
Post #51042 4th Jan 2011 7:43pm
Alexke
Belgium
if you open your window a tiny bit and put it on 0 ,: a venturi effect will suck air out of your truck , and in return sucks air into your heater ...
or
-solder an extra resistor and switch between it
- you could even do with a potentiometer - so you will get total control Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #51121 5th Jan 2011 1:45am
Mine does exactly the same thing.
The service bulletin is SSM39653, see:-
http://www.defender2.co.uk/gallery/albums/...er_fix.pdf
However this is stated to be applicable to LHD vehicles only, and mine is a 2007 RHD (on mine the passenger (ie left) side air is much hotter than the drivers (ie right) side).
Anyone know if SSM39653 is also applicable to RHD vehicles, or if there is an equivalent modification?
Post #51147 5th Jan 2011 11:02am
