Home > Tdi > defender 300tdi and disco 300tdi differences?
horus1970
England 1995 Defender 110 300 Tdi HT Portofino Red
as title says does anyone no the difference between a defender 300tdi engine and a disco 300tdi engine? I mean the bare engine without turbo or manifold or any other ancillaries,
I also know the engine number prefix will be different, just trying to get a spare engine for my defender and have seen lots of disco ones for sale, cheers lads Very Happy
Post #562962 10th Sep 2016 6:23pm
Mo Murphy
They're the same.
50 Shades of Pennine Grey
Post #562983 10th Sep 2016 7:19pm
horus1970
300tdi
thanks mo, wasn't sure if head would be different where manifold bolts on with the disco not having the same turbo location, thanks mate. Very Happy
Post #563245 11th Sep 2016 10:55pm
Mo Murphy
They are the same engines horus, even the manifolds. It's the 200tdi that is different between defender and discovery.
Hope that helps
Post #563268 12th Sep 2016 6:40am
What's the difference for the 200tdi please?
I know that the exhaust manifold is different due to the turbo location, but is anything else different?
Post #563295 12th Sep 2016 8:29am
horus1970
Hope that helps
Mo
ah thanks very much mo, that's egsactly what I needed to know, cheers mate, Very Happy
Post #563371 12th Sep 2016 4:09pm
Mo Murphy
@Blackwolf
The inlet and exhaust/turbo manifolds
Timing case, additionally less the timing belt idler
Injection pump brackets to suit lower FIP position
Injector pipes
Dipstick and tube
Power steering pump
Power steeing pump bracket
Alternator bracket
All the intercooler pipework
The airbox
Apart from that they're pretty much identical 😊
HTH
Post #563382 12th Sep 2016 4:52pm
Mo Murphy
... and not forgetting the water pump 😉 The Land Rover 90 - Many are called, few are chosen.
Post #563383 12th Sep 2016 4:54pm
Thank you, very comprehensive answer! Thumbs Up
I imagine that if one was considering retro-fitting a 200tdi into a series vehicle, an ex-Defender 200tdi is a better prospect than an ex-Disco version?
Post #563389 12th Sep 2016 5:02pm
Mo Murphy
Well they'll both work but the defender version will use all standard parts which always makes things easier. 😊
Post #563424 12th Sep 2016 6:19pm
