Home > Maintenance & Modifications > Roof panel modification
Conan
Belgium 1996 Defender 90 300 Tdi HT Coniston Green
Hi everyone, I would like to make a small modification on my Defender 90 300TDI. I bought it from someone in Belgium, but the first owner was from the Netherlands. Apparently, utility vehicles in the Netherlands need to have some sort of extension added on the roof so they are able to fit a standard box inside (it's a regulation). I don't find that very pretty and this make the vehicle too tall to enter my garage!!!! I was told that i could remove it, and weld a sheet of aluminum in place after I replaced a reinforcing bar... Does anyone has any experience with this or a similar job? thanks in advance for your help!
Post #561794 6th Sep 2016 7:48am
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
Would it not be easier to replace the roof for a standard one? After all it's only a couple of bolts and a friend to help you lift it on. Plus it's look much better than a welded sheet on there.
You could keep the current roof stored should you need to to comply with the regulation for any reason. Strong people are harder to kill and generally more useful!
Post #561801 6th Sep 2016 8:16am
Conan
I thought about it. I went to a garage that is specialized in Land Rover preparation and the owner told me that a new roof cost around 6000 euros... I looked on the internet for a used one, but couldn't find it... if you know where I can get one without emptying my wallet, I'd think about it again... Smile
Post #561803 6th Sep 2016 8:32am
dorsetsmith
Post #561808 6th Sep 2016 9:41am
VeeTee
Netherlands
Try http://www.marktplaats.nl/a/auto-onderdele...er-90.html
or http://www.marktplaats.nl/a/auto-onderdele...er-90.html
or MaanRover
or De Krim 4x4 Cheers, Vincent
MySite
Post #561879 6th Sep 2016 3:13pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Conan, if you can find one in the UK and fancy a holiday here, I'll help you change it over Smile
Post #562004 6th Sep 2016 8:54pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
For that kind of cash it would be worth taking a trip over for the Landy auto jumble at Newbury first weekend of October ?
Post #562032 7th Sep 2016 1:56am
Conan
Thanks all for the suggestions! I found a roof here in Belgium for 50 euros. It's a roof from a 110 that has already been shortened, but the job was very clean. I'm still going to fix mine though, just to see how it turns out. I'll take pictures and share them once the work is done.
Post #563188 11th Sep 2016 7:18pm
Conan
My roof is done!! My uncle and I did it this weekend, but I haven't had the time to post some pictures. We built a structure in the inside and bolted an aluminum sheet on the outside. It's solid like a tank! But the pictures don't do it justice... Oh and never mind the cardboard pieces on the inside, those are gone now.
Post #566833 26th Sep 2016 8:39pm
