Home > In Car Electronics > 13 Pin tow electrics live |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 328 |
On the factory 13pin kit the switched ignition feed comes from the battery via a relay that is triggered from the heated rear window switch supply (white/green wire on back of switch).
6th Sep 2016 7:34am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 |
Click image to enlarge |
6th Sep 2016 5:56pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
Thanks Both
Thats strange - i didnt see a relay in my 13 pin when i looked, ill go and have another look behind the trim and then go from there Mike |
7th Sep 2016 1:08pm |
The relay is normally fitted in the under seat battery box.
7th Sep 2016 3:01pm |
