Home > In Car Electronics > 13 Pin tow electrics live
mse
Which is the wire colour (at the grey connector preferably) that's an ignition feed? its probably really easy to find and i have the purple permanent live, but i could do with a switch feed for a couple of van lights/sockets and i don't want to mess with the main wiring loom if possible.
thanks Mike
Post #561761 5th Sep 2016 10:31pm
Fifth Horseman
On the factory 13pin kit the switched ignition feed comes from the battery via a relay that is triggered from the heated rear window switch supply (white/green wire on back of switch).
Post #561787 6th Sep 2016 7:34am
Romadog
Thumbs Up
Post #561930 6th Sep 2016 5:56pm
mse
Thanks Both
Thats strange - i didnt see a relay in my 13 pin when i looked, ill go and have another look behind the trim and then go from there Thumbs Up Mike
Post #562144 7th Sep 2016 1:08pm
Fifth Horseman
The relay is normally fitted in the under seat battery box.
Post #562172 7th Sep 2016 3:01pm
