Home > Puma (Tdci) > Small Regular Water Loss |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
not necesarily - but you could always get it pressure tested.
More likely to be something like a jubliee clip issue...i had a similar fault for years and only by chance did i catch the slight drip from a pipe and fit a second jubliee clip ( the first was tight and located perfectly). In the mean time i had changed a number of things. Mike |
29th Dec 2010 6:46pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Check both sides of the radiator as mine was poorly swaged plastic to ally core and the only signs was a green yellow algie like trace all the way down the sides. Also hot antifreeze has a curry smell to it If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
29th Dec 2010 7:42pm |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 |
I have found that some td5 and gems v8 engines appear to loose water on a regular basis.But they find their own level in the expansion tank,usualy below the the cold level line.
Next time the tank level is low try marking it and then check daily to see if it uses any more water. Its never over in my land rover. 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
29th Dec 2010 9:36pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
never had to top up ours in 30k miles 2.4 90 XS
30th Dec 2010 9:16am |
same here Mike |
30th Dec 2010 9:39am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
and here NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
30th Dec 2010 9:40am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2637 |
ditto, just past 14Kkm |
funrover Member Since: 12 Dec 2010 Location: Yorkshire Posts: 130 |
I've found that with my TD5 too, it seems to drop about a quarter of an inch but stays happily there. Editor of FunRover - One blog. Read it! Land Rover rebuild video series here: |
30th Dec 2010 11:54am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
The water level should change between Summer and Winter. As the Average temperature falls so the water volume in the cooling system, when cold, should drop to a lower level in Winter compared to Summer. Could this account for the changes noted?
31st Dec 2010 6:19pm |
so much for that...
I just had to put in 750ml of coolant in the Puma. There are no signs of leaks anywhere, and this is the first time this has happened. What should I be looking at in particular, and why didn't the EMS pick up the coolant loss? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
1st Apr 2011 6:23am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Check EGR cooler gaskets Original Member Pie n Pea Club.
110 HCPU Tipper |
1st Apr 2011 8:41am |
Hmm.. is the turbo also water-cooled or not? Could this have something to do with the EGR-shut remap from BAS? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
1st Apr 2011 1:24pm |
No, not watercooled turbo here Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
1st Apr 2011 2:43pm |
After I topped up the coolant this morning, I ran some errands. 80km later, the coolant level has gone down by around 5-6mm
No signs of leaks anywhere on the floor - guess it's a head gasket then -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
1st Apr 2011 2:45pm |
