Home > Puma (Tdci) > Small Regular Water Loss
nickhodgson
I have been topping up the coolant on my Puma consistantly since I got it. I was new and now has 30k kms on it. It seems that every 5000-7000kms I add about 2-300ml of water to the header tank to bring it back to the cold level. I have also made sure that the bleed screw location is also full of water at the same time.
Any idea where it could be going as there are no obvious leaks?
If it was something big like a head gasket problem it would surely have let go by now. Espicially as most of my driving is high speed in hot weather with the aircon on.
Also the engine temperature has never moved and the aircon has never cut out due to hot engine.
Nick
Post #50138 29th Dec 2010 6:00pm
mse
not necesarily - but you could always get it pressure tested.
More likely to be something like a jubliee clip issue...i had a similar fault for years and only by chance did i catch the slight drip from a pipe and fit a second jubliee clip ( the first was tight and located perfectly). In the mean time i had changed a number of things. Mike
Post #50143 29th Dec 2010 6:46pm
noworries4x4
Check both sides of the radiator as mine was poorly swaged plastic to ally core and the only signs was a green yellow algie like trace all the way down the sides. Also hot antifreeze has a curry smell to it If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #50152 29th Dec 2010 7:42pm
Toplink
I have found that some td5 and gems v8 engines appear to loose water on a regular basis.But they find their own level in the expansion tank,usualy below the the cold level line.
Next time the tank level is low try marking it and then check daily to see if it uses any more water. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #50190 29th Dec 2010 9:36pm
Grockle
never had to top up ours in 30k miles 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #50226 30th Dec 2010 9:16am
mse
same here Mike
Post #50229 30th Dec 2010 9:39am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
and here Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #50230 30th Dec 2010 9:40am
Naks
mse wrote:
same here
ditto, just past 14Kkm
Post #50231 30th Dec 2010 9:40am
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I've found that with my TD5 too, it seems to drop about a quarter of an inch but stays happily there. Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #50275 30th Dec 2010 11:54am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The water level should change between Summer and Winter. As the Average temperature falls so the water volume in the cooling system, when cold, should drop to a lower level in Winter compared to Summer. Could this account for the changes noted? Question
Post #50538 31st Dec 2010 6:19pm
Naks
so much for that...
I just had to put in 750ml of coolant in the Puma. There are no signs of leaks anywhere, and this is the first time this has happened.
What should I be looking at in particular, and why didn't the EMS pick up the coolant loss? --
Post #65819 1st Apr 2011 6:23am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Check EGR cooler gaskets Question Original Member Pie n Pea Club.
110 HCPU Tipper
Post #65833 1st Apr 2011 8:41am
Naks
Hmm.. is the turbo also water-cooled or not?
Could this have something to do with the EGR-shut remap from BAS? --
Post #65876 1st Apr 2011 1:24pm
dgardel
Italy
No, not watercooled turbo here Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #65890 1st Apr 2011 2:43pm
Naks
After I topped up the coolant this morning, I ran some errands. 80km later, the coolant level has gone down by around 5-6mm
No signs of leaks anywhere on the floor - guess it's a head gasket then Crying or Very sad --
Post #65892 1st Apr 2011 2:45pm
