![]() | Home > Tdi > LPG injection for diesel engines ?? |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
Didn't know anyone did it for MPG - I thought most did it for cheap Ooomph!
IIRC Malcolm Wilson's lad used to use a Freelander TD4 with LPG injection for reckying ![]() |
Electron Member Since: 28 May 2016 Location: Bideford Posts: 50 ![]() ![]() |
Ah so it's not an urban myth then ... they are using lpg to extend the range of an expedition truck.
The mpg claims were impressive but did involve beer .... Will ask who did it and if there is more detail ... |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 ![]() ![]() ![]() |
It is more common on big diesels. Trucks and marine application.
Prins make a system and I looked at it as a transport manager when I used to manage a small fleet of vans . I never pursued it as the cost savings weren't there to justify it. I did get several petrol/dual fuel vehicles on the road though. HR064 Hampshire and Berkshire 4x4 Response |
Toby60 Member Since: 06 Dec 2014 Location: Cheshire Posts: 28 ![]() ![]() ![]() |
As JJ says it is more common on large trucks as the benefits are greater.
Basically diesel is substituted by LPG at a rate of up to 25% depending on the engine's operating conditions. Vehicle with low MPG and that operate at constant speed, ie 44 tonne trucks on long distance motorway journeys achieve the best results / savings as opposed to light vehicles on stop start journeys. However I believe that Mercury Fuels (the vehicle converter) are developing something for the smaller diesel vehicles such as the 3.5 tonne van. Also the later Euro version engines are the best to convert as the ECU on these can be programmed to give optimum results across the full range of operating conditions and it prevents the engine from running too hot. More information on this can be found on the Calor Gas website and you will find a YouTube case study which outlines the results that they achieve from their LPG/Diesel trucks. Google Dual Fuel Calor ------------------------------------------------ 2002 TD5 90 HT County |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 837 ![]() ![]() |
Allisport used to do a propane injection kit for defenders.
def_fid Member Since: 07 Mar 2011 Location: worcestershire Posts: 17 ![]() ![]() ![]() |
I fitted the Allisport kit to my 300tdi 110 about 8 or 9 years ago. Still in use and working perfectly. One 26litre tankful lasts about 1000 miles. Power increase is about 10%, mpg about 33 with, compared to 26 without. Exhaust gas measured at MOT, is about 50% cleaner with LPG. In use now for about 35,000 miles.
Thanks to everyone replying on this ...
