Home > Maintenance & Modifications > Reduced Height Suspension ...
Jampot
United Kingdom 1994 Defender 90 300 Tdi CSW Alpine White
I've done a few searches on here and the internet but i'm not getting any where .
I've just measured the distance from tyre to arch and the rear is 6 inch and the front is 4 1/2 inches i'm positive it has some sort of lift on it but not sure what ..
I'm wanting to lower it from standard height maybe 1 or 2 inch but all links from google search fail.
I have a 1994 300 tdi 90 and also do i need to change shocks as well ....
Cheers ..
Post #559530 28th Aug 2016 3:32pm
Harry.O
Have a ganders here, they measure slightly differently but it has the standard distances in which you can compare with. http://www.gwynlewis4x4.co.uk/wp-content/u...rments.pdf
Post #559540 28th Aug 2016 4:38pm
Jampot
Cheers i'll try that tomorrow ...
Post #559544 28th Aug 2016 4:57pm
mikeh501
measuring tyre to arch isnt a great way to determine a lift. you are introducing many more factors than needed.
just get underneath and measure the length of the actual spring. this will at least give you the compressed spring length. Better again would be to unload the wheel being measured with a jack on the opposite side. This would give you the "free" length which is what you will see when buying new springs.
Post #559585 28th Aug 2016 7:37pm
Jampot
Cheers ....
Post #559600 28th Aug 2016 8:27pm
