Home > Puma (Tdci) > Leaking windscreen
I-Landy
United Kingdom 2007 Defender 130 Puma 2.4 HCPU Baltic Blue
Leaking windscreen
I seem to be getting water coming in when it rains either through the windscreen or I think more worryingly through the neoprene/rubber gasket below the windscreen. It's a 2007 model 130. Anyone had any experience of this?
Thanks,
Ivan
Post #559454 28th Aug 2016 9:03am
dorsetsmith
have a look at link for defender leak fix from LRJ
https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI
Post #559465 28th Aug 2016 9:22am
agentmulder
Kuwait
Yeah man, this is an issue here too, but only if I park with the right side lower than left.
Obvious solution is obvious Laughing
Will sort proper if/when I repaint vehicle and install roll cage. Solved the bowel problem, working on the consonants...
Post #559471 28th Aug 2016 9:50am
Harry.O
I ran a bead of Sikaflex along the foam seal and a bit behind the windscreen blocks for good measure. Don't use silicon because its a nightmare to paint over. That stopped most of it but discovered the windscreen seal itself was leaking, a small bottle of Captain Tolley's sorted it. It was a welcome fix having been driving in wellies previously Mr. Green
Post #559511 28th Aug 2016 12:23pm
K9F
Dirt build up on the lower edge of the windscreen seal causes this leaking too, the dirt acts as a wick.
http://www.defender2.net/forum/topic2126.h...creen+seal If you go through life with your head in the sand....all people will see is an ar5e!!
Post #559517 28th Aug 2016 1:18pm
